Best Options For Connecting My Iphone Via 3 Mm Jack!
Carl911
Hello all,
I have just purchased a 2007 gs450h and although I have not yet looked I am LED to believe that the gs does not have a 3mm aux to plug my Iphone into?
Assuming that is correct does anyone have recommendations of an aftermarket adaptor that will fit to the existing system which is the ML stereo.
Thanks in advance,
Carl
Either straight 3mm jack or a Bluetooth option. I use a u-play puck as a Bluetooth option but it has a bit of interference. Ok when turned up but annoying at low volumes.
Stuart
Thanks Stuart,
I don't really want the Bluetooth just a straight jack or usb will do.
Do you know what site sells these as it's not very clear if some are compatible on a few sites I have looked at so for.
Carl
