Locations Of Sensors Required + Bulkhead Routes For Cables
Seeing as I dont have a workshop manual for my IS200, I need to determine the following so I can wire up the HKS Camp.
I require:
12v ignition
12v constant
Ground
RPM Signal
Speed Sensor
Injection Pulse
I need to splice into each one of those.
Also, yesterday at boxhill Scarface showed me a way through the bulkhead, behind the Battery.
Are there any other locations as i've got a fair few wires and harnesses to feed through :blink:
do you need to know the pinouts on the ecu ??
nah, just literally where I can locate these wires so i can splice into them.
engine, fusebox, wherever. I just need to know where and the colours....
This thing is getting trickier every time i look at it! :crybaby:
they are all located at the ecu position
do you want a diagram ?
yes please mate :)
if you need to email it:
nickthegreek at rhapsodyoftheseas dot co dot uk
  • 3 months later...
