Lost My Only Key For Altezza
scott-altezza
hi im needing some help asap as iv lost my only key for my altezza, how will i go about this , i phoned toyota and they want £1200 for new barrels,ecu ect, i have acces into the car and it has an after market sigma alarm, but can not start the car ! all help is most appreciated :winky:
Independant firms are cheaper, but will still cost several hundred mate.
Several threads on this exact thing recently if you do a search.
I have a key thread pinned in the IS200 section of the forum too with lots of key info, i'm assuming the Altezza is the same?
i had a similar problem although it wasn't my only key, my key was just stuck in the ignition and wouldnt come out or twist to come out.
I had to get a new lock set which consisted of 3 keys, ignition barrel, barrels for the doors and boot and that set me back £300 odd quid including labour. that wasn't with a Lexarse dealer tho i might add! :)
Altezza's are not the same, no factory alarm on them :o
