Engine Cover Underneath The Engine Bay/rad Etc
Yep there should be a splash/cover underneath.
You normally have to remove this cover to do a oil/oil filter change.
If you don't have try and get one from a breakers/ebay or last resort your Lexus dealer (will be expensive from Lexus).
The cover is only held onto the underside with a load of 10mm bolts.
Yes there should be a cover underneath the car, not sure where to get one e-bay, local breakers, or even ring Lex sometimes there not as expensive as you'd think for parts, there just held on by clips and bolts takes a couple of minutes to fit.
Cool mate. Is it the forward engine cover or the other one thats further back? Why did u remove them from ur cars? lol
edit: is it cover number one or two which you have mate?
http://www.toyodiy.com/parts/p_E_2002_LEXU...EPVKW_5102.html
Cover Number one mate. Its the one that sits under the engine and attaches to the front bumber. I took them off when the cars got supercharged and just didnt want to cut them up to put them back on!
Tom.
