IS200 Steering Wheel Removal
Description
workshop disclaimer applies
DISCONNECT THE BATTERY NEG- TERMINAL
Removing the steering wheel
:SEE AIRBAG PAD REMOVAL FOR PART 1 OF THE OPERATION (listed in Knowledgebase)
  1. Disconnect the connectorIS200 Steering Wheel Removal
  2. Remove the steering wheel set nut
  3. Place matchmarks on the steering wheel and main shaft assy
  4. USE special tool(puller) to remove the steering wheel
Extra Fields
General
  • Time Taken?
    15 Mins
  • Difficulty Level? 1-5
    2
User Feedback
Recommended Comments
There are no comments to display.
Add a Comment
