Description
How to bleed your SC430 brakes.
NOTE: Do not let brake fluid remain on painted surfaces. Wash it off immediately
This is a 2 person operation
(1) Fill reservoir with brake fluid to specification:
SAE J1703 or FMVSS No. 116 DOT3
(2) Connect the Bleed tube to the caliper(nipple)
(3) Depress the brake pedal several times, then loosen the bleed nipple with the pedal held down.
(4) At the point that fluid stops coming out, tighten the bleed nipple, then release the brake pedal
(5) Repeat 3 + 4 untill all the air in the fluid has been bled out
REPEAT THE PROCEDURE FOR ALL BRAKE LINES AT EACH WHEEL
Torque: 11N .m (110 Kgf.cm, 8 Ft.lbf)
Extra Fields
General
Time Taken?
30 mins
Costs?
none
Difficulty Level? 1-5
3
Recommended Comments
There are no comments to display.
