br1anstorm
Replacement radiator for IS300
When replacing the a/c condenser recently (and that's a whole separate story....) on my 2002 IS300 Sportcross auto, I noticed what looked like a slight weeping leak from the radiator.  It's not impossible that the tubes/fins might have been damaged in the process of removing the old a/c condenser, as it's a tight squeeze.
So I have been looking into getting a replacement radiator, and I'm getting a bit confused by the astonishing range of specifications, brands, and prices.
Leaving aside the custom-welded high performance aftermarket rads (which aren't cheap), it seems there are various differences in what is available.
1) auto v manual.  Radiators for auto transmission vehicles have to have a transmission oil cooler - which means a small separate cooler along the bottom of the rad, with two "extra" hose connections for the oil lines. Rads for manuals don't have this.  But... it seems that manual vehicles can use the rad for auto vehicles, and just leave the  oil cooler unconnected.  Obviously it's not possible to do it the other way round (you can't put a rad for manual-only into an auto vehicle).  Problem is, a lot of aftermarket suppliers don't make clear whether their product has the oil-cooler or not...
2) tube size.  The Lexus OEM radiators apparently have 25 mm diameter cooling tubes, whereas almost all aftermarket ones have only 16 mm.  Some say that in most conditions this doesn't make much difference to cooling-performance.  Anyone care to comment?  The difference is that 25mm rads are only available as Lexus OEM and twice the cost of aftermarket alternatives, which are mostly 16mm or don't specify.
3) IS300 vs IS200?  An older thread here asked the question whether their radiators were the same.  The answers were not clear:  one said the "fan cowling" was different (but this isn't part of the radiator....!).  Another said the Lexus parts list had the same number for both.  For the IS300 I have found 16400-46560 and 16400-46561, and also 16400-46720 and 46721.  Can anyone confirm definitely whether an IS300-auto radiator and an IS200-auto radiator are in fact the same? This matters because there are lots of listings on eBay and from parts-suppliers for IS200 rads (a much bigger market) and few of them indicate whether the item will fit an IS300 (which are much scarcer...).  If they are the same, I can browse for an IS200 one, as there are many more to choose from!
4) Alternative suppliers and part nos.  The range of brands and prices is huge.  Does anyone have a reliable cross-reference list? I believe Lexus OEM radiators are made by Denso.  Cost around £245 from a dealer. I have seen aftermarket items from Nissens (Danish) p/n 646924, cost £130-ish;  Koyo (Japanese, sold by Euro Car Parts) p/n 203820450 - not clear whether this fits both IS200 and IS300 - cost around £100.  Other makers include TYC p/n 2356, Spectra CU2356 - and there are others.  Has anyone had experience - good or bad - of particular aftermarket brands? I don't want to get a replacement which doesn't last.... but £245 for an OEM item seems unreasonable.
Bump....
I'm bumping this up in the hope that it might inspire a reply or comment from LOC technical gurus, and because I've had PMs from other forum members asking if I have got any more information yet.  I'm still wondering whether an IS200 and IS300 radiator are actually the same - or at least interchangeable.
Any responses would be welcome!
  • Similar Content
    • By sannyp
      Hello,
      So I recently got into a little accident with my is200 manual and now need a new rear hub, and maybe other parts although unsure what yet. Question is will parts from a is200 auto suffice. So I wanted this post to outline the differences.
      I know the differential is different with a higher ratio i believe, and obviously the tranny. But is there anything else?
      I have a guy ready to sell me a bunch of parts from an auto is200, but I'm sceptical with mine being a manual
      thanks
    • By WilliamH
      Had to get a replacement Battery in a hurry today for my 2003 IS 300 Sportcross, so went on-line.
      Eurocarparts website was easy to use and had a tasty discount offer. They had a choice of 2 so I selected the more expensive one with 70Ah, CCA 540A, rating and ordered it 'click and collect'. £67.40 inc vat and 3 year g'tee which I didn't think was bad.
      Now I've got it home I can see it doesn't fit the Battery tray properly. The base area is too big to fit deep in the tray so it sits quite high. Also, the new Battery is 10mm taller than my knackered Battery. As a result, the standard Battery clamp won't fit (the rods aren't long enough) and the terminals are worryingly close to the closed bonnet.
      Is this a common issue?
      Is there a work around or will I have to return it to eurocarparts?
      Is there a generally recommended/ easily available Battery that fits?
      Thanks in advance for your replies!
    • By J Henderson
      Having a much-needed clearout. Collection from EH51, or can arrange postage at buyer's expense.
      IS200 "Sport" Chrome Tailpipe
      Hard to find genuine item in very good condition. The underside a little pitted but not visible once fitted. Adds a touch of class to any IS200/300 with a stock exhaust system. £20
      IS200 Drive Belts
      Full set of Gates drive belts for 1G-FE engine cars - Power-steering, Air-con & Alternator. Brand New, never fitted. £20
      HB4/9600 OSRAM Fog Breaker Bulbs
      Colour temperature approx 2600K (Yellow). Brand-new & sealed. Will fit front fogs on '99-'03 1st Gen IS or '05-10 2nd-Gen IS (and possibly others..). £20
    • By Neddypong
      IS300 SPOTRSCROSS 2001, 75k fsh
      Mystery water loss
      Hello All.
      I like many others have exsperienced water loss with no obviose leakage. For the the last couple of years it wenr from an occaisional top up to having to fill the rad every 70-100 miles. I thought it may be a pressure problem and changed the rad cap. Then a water test for head gasket, Phew. The car ran perfectly as all ways and Over a long period I studied the engine etc waiting for something to rear it`s ugly head but nothing and no sign of a leak
      BRAIN WAVE....... I dismemberd 2 high lighter pens and decanted them into a gallon of water and put it in the car and in a dark place went over the engine etc. with a cheapo ultra violet light and voile......A small sweaty leake in the radiator.
      The rad has a lower tank and was leaking and the point where the core meets this lower tank. This lower tank has a raise lip of sevral millimeters and the water was sitting in what ammouted to a trough and then on I presume was just evaporating through the heat and wind so there was no easily visable sign.
      I got a standard rad from fleabay for about £150.00, by way of a foot note, it had  two fixturs to accept some piping that was not required on my model of  car. I fitted them anyway after crimping them shut and soldering the ends and the good woman fitted it two days later. This was three weeks ago and the problem is solved.
      I thought I would share my exsperience because thats the kinda guy I am.
