Changing Front Wheel Hubs - Ls430 2002
Hi all,
My front wheel bearings sound like they're on the way out and I'm just about to order the new hubs to swap - It's done 170,000 miles so I guess that's not bad.
I'm just wondering how to get the speed sensors off the hubs. In the manual there is an SST that looks like it grips the sensor carefully but I don't have access to that kind of tool. Is there another way I can get the sensor off (eg. using a normal puller or carefully with a screwdriver) or should I leave it to the workshop people.
Any suggestions would be welcome - especially from those who have done it.
Kind regards,
Mike
  • 1 year later...
Did you manage to get this done? I've got the whole hub assembly for my 2001 LS430 and I can't get the hub out of the car I've got the bolts off but the hube won't budge. I can't figure out if I need a puller, and if so how to attach it since there is no axle that stays in this case?
