nx450+ missing door lights
mickeyt
23 minutes ago, mickeyt said:
new nx no lights on front doors at the bottom any one else noticed this the cut outs are there
Apparently puddle lights only standard on the Takumi spec. If you carefully remove the black plastic filling the gap, you may be lucky and find the cable there all waiting and plugged in behind. I’ve ordered two lights from Lexus parts direct - £18 each ish. Not received them yet but should hopefully be an easy fit…
