Check Engine Light For '94 Es-300
kingtut
'Check Engine' light came on and stayed on 2 wks ago. If engine is turned off and back on w/in 15 minutes, the 'Check Engine' lights up and 'O/D Off' contininuously flashes. I took it to a local repair shop, who checked it and indicated that it may be a transmission problem. They tested drove the car and no problem with the shiftings or transmission. The local repair shop reset the light. Two days later the same lights come back on.
I just took my car for a smog check. The computer from the smog check place indicated the manufacture code of P1705 for the check engine light. Anyone know what this code # means? :unsure:
  • 5 weeks later...
it doesn't sounds like it
it might be a wire
loose
but it is hard to say exactly the problem as i am not even sure what it is trying to say with the above fault
it just might be the tranny selector is not engaging all teh way all teh time
a condition that can be caused by the engine mounts also
but it still affects teh tranny
do the ligths on the dash show the proper selection of gears all teh time?
