Engine Cut Out. Help
chri51808
Hey guys major help needed, came out to my lex after work and engine management light was on and trc light were flashing every few seconds going up a hill engine bogged right down n came to a stop.
No overheating no smoke nothin. If I try starting back up after few minutes itll start rev up and cut out again.
Anyhelp would be brilliant. I am litruly stuck in the middle of no where. Cheers
Where abouts are you? Getting the fault codes read will probably help the most assuming there is petrol etc. If a LOC member with a reader is close enough they may read them for you, i.e. I will if you are near Basingstoke.
