Is 220D 2007 Manual Ecu Reset Help!
Hey guys,
I have a 2007 Lexus IS 220 UK. I was hoping to do the ECU reset, as I bought it second hand to see if it improves mpg. I wanted to do the fuse method, I looked in the engine bay at the second fuse box. I could only find the ECI fuse, I could not locate the ETCS fuse.
Do I have to pull out a different set of fuses for this model?
Many thanks in advance
