Is250 Aux Belt/tensioner
natesis200
I've just started getting a squealing noise on idle on my 250. Its in an 55 plate and done 75k. I've searched a generic "car parts" specialist and the belt is easily found, but the "tensioner" they sell seems to be only £80. Whereas on eBay there is a kit comprising if more than just the tensioner pulley. Am I better off getting the kit from eBay? The belt looks in very food condition still so unsure which to change. And is it a job able to be done at home if put on drive on ramps/axle stands?
See my more recent thread on this subject.
I've had a look under the bonnet of my car and you MAY be able to access the belt/tensioner from above by just removing the front plastic cover.
If you think the belt is in good condition then perhaps it's too slack so if it's a manual tensioner tighten it up.If it's an auto tensioner then I would try a new belt before exploring the complications of replacing the tensioner,or should I say tensioners because it looks like there are two small tensioner wheels to me.
