sannyp
Is200 Auto vs Manual parts
Hello,
So I recently got into a little accident with my is200 manual and now need a new rear hub, and maybe other parts although unsure what yet. Question is will parts from a is200 auto suffice. So I wanted this post to outline the differences.
I know the differential is different with a higher ratio i believe, and obviously the tranny. But is there anything else?
I have a guy ready to sell me a bunch of parts from an auto is200, but I'm sceptical with mine being a manual
thanks
  • Similar Content
    • By tom price esq.
      In need of parts in kensington green 6q7 :
      front bumper nearside wing nearside front door  nearside rear door I don't need the door cards, just the door with window, exterior handles and electric folding mirror for the front, plus if the bumper has the washer jets that would be great!
      How much would I be looking at paying for all of these parts? if I could get these delivered that would be excellent!
      Apologies if this has been posted in the wrong section, a bit frantic at the moment.
      Best,
      T
    • By Magic7032
      Before I start I have spent quite a few hours looking and reading posts, but most are old and photos no longer available and also many post were pre having 3rd party harnesses available, I’d prefer to avoid cutting and splicing
      ive removed the 6cd changer, got the new fascia, got a stereo, got everything I thought I needed and built and framed it etc, went to plug it in and no go.
      the plugs that are quoted and in the set I bought have 2 separate connections but only 1 come out of the back of the CD player and are all different shapes. I have read I may need to access the amp wiring but it’s pretty tight around the amp so will wait before having to remove if required
      photos, CD player back, cable plugs into right side socket then I assume through the dash behind the glove box to the amp, and other photo is the adapter kit I got which is the same as Halfords etc for a Lexus/Toyota loom
      does anyone have any guidance please?
    • By fuegos
      Hi guys,
      I am after the following bits:
      - front grille with bonnet catch
      - bonnet lock
      - set of genuine lug nuts
      - front RCA
      - passenger front door in 4P2
      - bonnet in 4P2
      - front bumper in 4P2
      - fuse box cover in black - under dashboard - driver side
      Thanks.
    • By pawlopc
      Hi ,
      I have some problem with my 1999 IS200. When I try to open doors using key, only driver door opens. Power door locking doesn't work. When I try to close doors using indoor switch, it doesn't work as well.  Same goes for locking it with the key fob. Only lights blinks but doors don't open or close. Opening boot with key fob works correctly.
      Has anyone any ideas ?
    • By Laim1987
      HI im new here. I looking to put 10mm wheel spacers n maybe some one knows do i need new bolts or something else? Or it's fits on original bolts? Thnx
