Rear Trim ReInstallation On RX300
few pics from refitting rear trim on my 2004 car .
probably a 2003 Build.
New amp arrived was fitted,straight forward plug and play
sound system all up and running Yipeeeee.
Cleaned a lot as i refitted
straight forward methodical process
also re colored all those unreachable parts
while the rear was disassembled .
20180814_144130.thumb.jpg.883196dd638e23daf3546d78993eef3b.jpg20180814_153011.thumb.jpg.1ed85c069ff60f3804702e791cc3a37c.jpg20180814_153003.thumb.jpg.c3eb214dd18a314d0aef3d82d80f2bbf.jpg20180814_144205.thumb.jpg.ed29129cd8f2b2a07d226620d0334eb3.jpg20180814_141404.thumb.jpg.41c96a106c8e5bd0d3f20ec459e09320.jpg20180814_150404.thumb.jpg.467c97ab6889c8b763e3c46ad1439f3d.jpg20180814_143838.thumb.jpg.c8dac334b3cd41d9b7de7fe29acd3aab.jpg20180814_144130.thumb.jpg.883196dd638e23daf3546d78993eef3b.jpg20180814_144224.thumb.jpg.a7e01e04a51521226a22ba8f79884f49.jpg20180814_152959.thumb.jpg.8731db589812837826a92d170e65b16c.jpg20180814_152955.thumb.jpg.5cbb989db5d516c037fed1c3383e10c5.jpg
  • 6 months later...
30 minutes ago, RoryRX300 said:
Hey, I'm also in Brighton with an RX300 and I need to locate the Antenna Amplifier; any ideas? Rory 07955 514379
That's going to be a very big job because according to the workshop manual you need to remove the headlining to gain access - that's NINE pages-worth of stuff to remove!. The amplifier appears to be the device on the roof that the aerial rod screws into, so you unscrew the rod from outside but then have to drop the headlining to get to the fixing inside.
