Help Needed
Imperialrs
Hi there i have been looking through the posts but i cant see to find an answers on a couple of things.
1. I need to change the diff oil on my Lexus and i am pretty sure lower hole is to drain on the side of diff and the one a it higher is for topping up is this right? I beleive you keep pouring in until it starts coming out?
2. Does anyone have pictures of the followings areas, i stripped my car down and didnt get any pictures of specific areas(just for rebuild)
1. Position of rear brake line to chassis bracket.
2. Pictures of bolt at rear subframe to chassis.
3. I have two sets of camber adjuster bolts. One set has round flange is this for lower arm to hub bolt? The other one is round then a straight edge, pretty sure this is for the toe adjustment?
Any pictures would be great.
