P1126 fault code
bristolninja
I have this code which I know is something to do with the throttle body magnetic motor so I cleaned the throttle body and cleared the ECU which it stayed off for 3 days temp outside hit 30 degrees , EML come back so I reset ECU same thing went out after 2-4 days came back on but only on start up … what can I do next before I take it to a garage which will cost a fortune?
