Boot roller blind
2 hours ago, John Reynolds said:
Recently purchased a 2017 CT200h but seem unable to remove the boot roller blind-any advice appreciated
The ends of mine are spring loaded, but I have a 2013 62 model, maybe the design has changed.
As above both ends of the blind are spring loaded and fit into a recess on both sides it is a bit tricky to master at first.
My method is to push one side into its recess then pull the spring end only on the other side and take the unit out at an angle.
