So i have a GS300 and it requires lower control arm bushes, i am in a bit of a dilemma of what parts to go for, febi bilstein/blue print bushes can be had for around £60 each although i have found whiteline poly style bushes for £80 for the pair, ive added the link to these below.
https://ukwhitelineperformance.com/collections/all/products/w53625-control-arm-lower-inner-rear-bushing
Interested what bushes you guys have used if you have the febi/blue print ones how have you found them
Or better still if you have poly bushes has it made it worse in terms of harshness on the road?
That is actually a good option thanks, they work out cheaper than two non genuine bushes....providing there is no import duty etc.
They do appear to be a common part across all the models and seem to be interchangeable from the numbers ive cross referenced.
