Is200 Service Checklist
Hi peeps.
I've hunted around for an is200 SE 80k service checklist I saw on the forum months ago, I'm getting mine done next week by a local garage, so would really appreciate if anyone has a full checklist I can go through with them.
:D
thanks
jack
Hi peeps.
:D
thanks
Jack
Minor Service - IS200 and IS300
(10,000 miles or 12 months - whichever is the sooner)
* Drain & replace engine oil (Mobil 1 Fully Synthetic) including 1 litre top up pack
* Replace oil filter and replace sump washer
* Check coolant, top up if required
* Replace key remote Battery
* Check & report on brake pads & discs
* Check & report on tyres and tyre tread depths, adjust pressures as required
* Check corrosion & body damage and report as required
* Check windscreen & wipers & top up washer fluid
* Check suspension ball joints & shock absorbers
* Inspect clutch fluid
* Inspect air filter, clean if required
* Check all lights for cracks and all bulbs are working
Major Serive
(20,000 miles or 12 months - whichever is the sooner)
* Check alarm, power windows and central locking systems for correct operation
* Inspect exhaust system and mountings and check leaks
* Inspect fuel tank, lines and connections and vapour control
* Inspect drive shaft boot covers
* Check brake and clutch pipes for leaks and check connections
* Check power stering fluid and top up if needed
* Check drive belts for wear and deflection
* Check transmission oil
* Check brake and parking brake for free play and travel
* Check steering wheel free play and linkage for wear and security
* Replace Diff Oil
* Replace Air Con filter
* Replace brake fluid
Service done.... total cost was **£99** including the oil change. Bit of a difference last year, when Lexus in Bromley charged me £650... oh they did change the windscreen wipers I guess.
:D
They showed me a couple of bills brought in from other customers, dealers charging £400 for a service worth £100.
Might just keep the old banger another year :hehe: B)
Hi jxmac. I bought myu IS200 SE last week and my nearest Lexus centre is Bromley too.
What are they like to deal with? Reading this forum thoroughly, it appears that they are not highly thought of. The previous owner of my car lived in Woodford and got all his work done by Lexus Woodford who score very highly here...
