Esso Super Unleaded
dribble
  • 5 years later...
Normal unleaded isn't "watered down".
95 RON self-ignites at a lower compression than 97 RON which is what Japan uses. This is how diesel engines work; by self-igniting; no spark plug.
If your engine has a compression ratio of about 10:1 or higher, you need the higher RON "super" fuel. Otherwise, the engine will compensate with its anti-knock/pinking sensor and back off the timing. The whole idea of a higher compression is greater fuel efficiency. But if the timing is backed off it loses this advantage.
Fifth Gear showed a Subaru Imprezza makes full use of super unleaded and gained several percent in power and torque.
