Injector Problem
IanCornwall
Hi all
been ages since I have been online, hope everyone is OK
due to work and all sorts of stuff needed doing I haven't had much chance to drive the Lexus for a while, mostly down to being a bit poor, but things are better now so it is on the road again
I now have a missfire, running on sort of 5 and a half cylinders
Number 5 cylinder is def the problem (pull off spark plug lead test)
New plug fitted, still the same
Injector seems poorly and fuel cleaner makes no difference at all
Removed injector and swapped it around missfire moved to the new cylinder so seems almost certain injector is screwed
You don't wanna know what the main stealers want for an injector !!
Has anyone a source for injectors at good price ?
Has anyone any used injectors laying around (maybe having upgraded theirs) ?
Are Supra Mk4 injectors the same ?
Are 1JZ-GTE injectors the same ? as I can get some of them cheap
Help please
:crybaby:
