Power Supply Problem
I recently got an Audiovox power supply from an old handsfree kit. I hope to use it as a 5V supply for a satnav and also for a mini hard drive. Problem is I can't get it fitted properly. There are 3 input cables - a positive, a negative (both with inline 2A fuses) and a thinner wire which I have no idea about???? There are 4 output wires which should be ground, 5V, 9V, 13.7V (the car Battery voltage). I don't know which colour corresponds to what voltage as I can't get it up and running. Every time I connect the thing to the car, I blow the inline fuses on the input cables. Has anyone any ideas how to fit this power supply????? Anyone who has fitted a handsfree kit themself may be able to help. Thanks.
