Revs Itself Then Cuts Off!
BenEP2
when i start my car it revs up to 3k revs then cuts it self off!!
Does anyone know why this is?? please help as cant seem to find any one who knows
Cheers Ben
Try throttle body, sensor and position switch
I had similar prob with my last tezza and turned out to be the spring in throttle body had snapped
so every time I revved it, it cut out
ok thats interesting, Was it hard to get sorted eg price and do they have to take the engine apart so to speak?
is that the only reason this is happening or could it be something else like a fuel sensor?
Cheers again ben
Cheers again ben
When i had my tezza diagnosed 1st it came back with 22 faults .LOL
but after the guy cleard the faults it came back with 3 which were throtle sensor, throtle switch & Ecu.
It was non of them either
it was the spring that springs the throtle back it broke and was keep getin traped.
I needed a replacement throtle bodie but i never changed because it was well over a 1000 pound new and i couldnt find 1 from scrappy
so a used the position switch to spring it back and it worked fine.
the only other thing i can think it might be i mass airflow sensor on air box/induction kit
but before you start messin i would recomend you get i diagnosed which will help you out better than random guesses
