Lexus = Toyota
hi fatmax'
any key will work if its set up to ur lexus ecu.
if its not programmed it wont work.
hope that helps - :shifty:
thanks for reply mate . but i have tryed to program the key but when i get to number 6 and the doors unlocked. can not get the doors to lock on number 7 and 8 anyone
This procedure is used to register additional key code(s) while retaining previously registered key codes.
1. Insert the key in the ignition and, then remove it.
2. Press the driver’s power door lock switch, LOCK to UNLOCK, 5 times.
3. Close and open the driver’s door.
4. Press the driver’s power door lock switch, LOCK to UNLOCK, 5 times.
5. Insert the key in the ignition and cycle the key from LOCK to ON to LOCK.
6. Remove the key from the ignition.
The power door lock switch will respond by automatically cycling from UNLOCK to LOCK to
UNLOCK confirming ADD MODE.
7. Press the key’s lock and unlock buttons simultaneously, then release.
8. Press either the key’s lock or unlock button for one second.
The power door lock switch will automatically cycle from UNLOCK to LOCK indicating the following:
ONCE to confirm that registration was complete.
TWICE to indicate that the registration was unsuccessful.
9. Additional key codes may be registered by repeating steps 7 and 8 above
