Reverse Camera
Hi im haveing problems with my reverseing camera the screen changes from sat nav to the reverse screen with the green lines on BUT the screen is all fuzzy (like when you remove the aerial from the tv),so there must be power at the gearbox end,just woundered if anyone else has had this fault as a new camera is £650+vat which i regreat paying if anyone could shed some light on this it would be greatfull cheers kev
  • 2 months later...
you dont have to pay all that i have seen cameras on eBay very cheap im sure you could use one of these but im almost sure they are ntsc format so this is the type you need
it could even be a broken wire in the grommet that goes in between the rear door worth a try hope this helps
