Can I Fit These Tryes?
According to the spreadsheet I made earlier to calculate such things, there is an increase in circumference of 1.4%
So the speedo will read lower by 1.4%, not really a problem, I would have thought. Theoretically, the taller sidewall will give a softer ride, whether it would be noticeable or not, I don't know
When I bought winter tires for my Ls400, I asked can I fit the 65 tires, but answer was no. So I replaced them with standard size.
Of course you could try and see what happends if you fith the 65 tires.
thanks for that. appreciate the response. personally i cannot see there being a problem. If a 65 is 5mm bigger than a 60 and the 65 is already part worm then i dont think they will be that much bigger.
cheers.
