Dashboard Warning Lights
took the lexus for a drive down to holyhead this week got a few good photos of the car , didnt do to bad on juice either.. however on the return journy, my ABS, TRC and door open light started to flash..
when driving only the door warning light would flash rapidly
in stand still traffic the trc and abs would start to flash too
no affect on the drive on the car pulled well and braked fine
i disconnected the Battery to reset the ecu, the errors again popped up after 5 miniutes..
started the car this morning and no warning lights cropped up at all even after driving from stafford to manchester and back...
havnt had a chance to connect to OBD and have read some older threads but not getting anywhere
also rang lexus they couldnt help but said would kindly charge £115 for an OBD check :msn-oh: !!!!
any ideas what it could be cheers..
as im aware the screen is from the factory its not been changed, ther is a crack at the top around the mirror but this hasnt ever let water through..
checked the footwells there bone dry, only signs of water are in the depth and sides of the boot floor
had the car diagnosed today, was expecting a faulty sensor but was surprised to see that nothing appeared up on the diagnostic..
guessing it was just a electrical glitch
