Dealer Info Message On Satnav
Hi Folks
Just wanted to double check, I'm getting a message on the sat nav about my local lexus dealer, at the top it states 'engine oil' and 'servicing'. I'm guessing this is just some sort of a broadcast and car is not needing an immediate service or has a problem of any sort?
Any engine issues, I'd expect the lights on the dash to appear?
Thx
If the car was low on oil you will get a warning on the speedo. A red triangle will illuminate and there is an audio beep too.
Sat Nav advisories are based on data input by dealers at service.
As I thought, thank you for confirming.
