Premium Navigation
Centre100
CT200h 2016 UK version with Premium Navigation.
What can you do with the result of a Route Trace other than rename it, delete or confirm the start and end points?  Other than seeing the result on the map display what is its purpose?  Can it be saved as a route to use again and therefore get tailored traffic information? If so how?
Anyone managed to find a use for it?!
Route trace can be handy if you wish to record and save a particular trip, for instance a particularly scenic route that you wish to re-use but that would not be typically selected by the satnav. I have also used it to temporarily save a route that avoided roadworks.
You can edit/delete a Route Trace from the "My Memory" screen.
I have only used it a couple of times, although I have never tried to edit a saved route.
Note that a route trace is limited to a max of 124 miles / 200 km
