Abs Sensor/system On The Blink?
Following on from a previous post regarding struts and braking system - found nothing amiss, I am leaning towards thinking it is possibly the ABS?
It would appear that this temporary juddering/noise that ONLY occurs at low speeds, say 5 - 20 mph could be the ABS engaging? is the sensor malfunctioning and has anyone else had experience with this? Is the sensor an integral part of the hub on a MK3 or a seperate item and is this a part which requires replacement after so many miles?
Any ideas gentlemen?
Thanks.
I had this problem on another car, exact same problem, all I did was unbolt the sensor, cleaned it and bolt it back on, and it worked fine after that
Not quite finished yet Gentlemen - does anyone have a schematic of where the sensor is located please?
Steve2006, where are you?
