Wheel Off Set
Hi all
I've seen some nicer who sets of shine you black and silver wheels I'd like to get for my IS200, now I'm not to sure if these are gong to fit straight on or not they are the same size 17" and here are the numbers
5x114.3 5x115
ET45 ET47
17x7j 17x7.5
Now I know the bottom is wheel size 17 diam 7- 7.5 width which I know should be ok but are the other measurements ok will they fit straight on with out no props
Thank you in advance Darren
The first lot of numbers are the stud pattern so it means 5 studs/holes the next number is the distance between the studs/holes toyota/lexus are 5 114.3 so the 5x115 may not fit. The et number is the offset which determines if the wheel sits further in or out the arch the standard wheels are et50 on a 7j wheel I run et30 on the front and et25 on the rear with 18x9.5j but iv rolled my arches so et45/et47 on a 7-7.5j will be fine may look a bit lost in the arch in my opinion but i like the wheel flush with body.
Hope this was some help.
Joe
