I was trying to work out my heater. I often set it at around 21.5 degrees and find that this is a comfortable setting. Usually there is just a hint of warm but not cold air through the vents. Other times I find the heater blows cold at this setting. I have to up the heater temperature to around 26 degrees before I get hot air again and then it gets too hot quickly.
the climate seems to have a mind of its own and I wondered if this is all effected by the outside temperature.
has anyone else noticed this variation in temperature being a little random?
carl
