Adding night view to ls600hl
Hi
does anyone know if it's possible to add or activate the night view system on a 2011 ls600hl.
The car has pcs, Lka and adaptive cruise so all of the required cameras are fitted. Looking on an online epc site the only part listed on the night vision page is a cable from the boot ecu to another one under the dash. If this cable was fitted would night view work or does it need additional equipment. According to the epc site there is only one version of instrument cluster so it should work.
Many thanks in advance..
wacko
I have on my GS, but it has been dismissed in later versions; probably it's not possible to add it in your LS because are needed also IR lights and probably IR sensitive cams, but if in newer LS the feature is present may be asking to yur Lexus dealer you could, paying too much money, even if the system is effective in seeing  people in dark areas.
