Sump Gaskets/Seals
Ailandas
Hi All,
My sump gaskets are starting to mist with oil quite a bit after having a look at the engine compartment so it seems that they will need changing fairly soon. Has anyone done the job before on a 2jzge? Does the engine need to come out? Anything else you would recommend changing while doing the gaskets?
Cheers!
Hi Ailandas,
I hope that the community will be able to answer your questions about the process of replacing the gaskets. If you need any parts, please do give us a call or send us an enquiry, we are always happy to help. All our products are heavily discounted and much cheaper than what you would find at a main dealer!
Kind regards,
Jon
