1999 IS200 Automatic
Kona200
Hey! I have a little problem with my IS200. Car cranks good but wont start. I smelt fuel from the exhaust so i tought it gets fuel. Then i checked plugs and they give spark, sparking looks kinda slow not sure. Also checked fuel pump but its not making sound at all. While starting pump, it gets right power to the pump connector so relays,fuses should be ok. Then i threw some fuel straight to the cylinders and it almost Fired up. Bad fuel pressure and pump completely broke?
