Do I have the latest version of Lexus navigation?
We've just bought a 2020 NX 330h with the larger display. How do I find out if I have the latest version of Lexus navigation? Can I see my current version displayed anywhere? thanks in advance
If this is the same as my RX450h
1. Press the “MENU” button on the Remote Touch.
2 Select “Setup”.
3 Select “Online” on the sub menu.
4 Select “Lexus online”.
5 Select “Map update”.
6 Select "Current Map Version" to show the current map version
51 minutes ago, Neo_gsf said:
By the way, the latest version of the maps available to download from https://www.lexus-tech.eu/ is "2022 v2"  (which is 2022 Q1 data)
Tried that, it simply took me back to Lexus for over the air updates, which on the odd occasion have worked take "forever" to download
You have to have a login on that site, and then select the menu items as follows
"Home"
"Payable Access"/"Map and Software Updates" (1st 3 years of owning car are free, I believe)
"Lexus Premium system (MM17 & MM19) Maps" - select the "Update" button
Then follow the instructions.
Yes, it takes about an hour to download the map updates to your pc (or apple if you are so inclined....), then you put the files on a USB stick, properly formatted as per the instructions, and then put the USB stick in your car and perform the update.  This step also takes about an hour and make sure the car is on (in the READY status" otherwise the car will switch off after 20 minutes.
