Fuel trim values
perseuss69
I was checking live data one day, and something seemed strange to me. With the engine idling at operating temperature, bank 1 long term fuel trim stayed constant at about -4,8% and bank 2 at +7%.Why is one bank negative and the other positive?
So far I've seen people talk about a leaking injector on one side, injector harnesses being swapped and AFR and 02 sensors connectors being swapped. Or just a bad O2 sensor. By being swapped I mean sensor 1 connected as sensor 2 for example.
AFR sensor video (I create a vacuum leak at one point):
 Fuel trim readings:
  • 4 months later...
