Sign in to follow this
nowden
Console Bulb Replacement
:duh: i have a bulb gone behind the aircon controls so only got half a console lit up lexus want big buff any one know how to sort it out pls
if you get the bulbs form lex, then its only a 20 minute job to replace,
basically you need to pull the heat switch and TRC button panle off, this pulls straight out, then you will see tow bolts, remove these, there are another two of these bolts up top, you willneed to get to these by reomving the top tray,, i assume its similar to the sat nav, by means of removing a cover, undoing two screws then pulling the whole cat nav/tray out. you will then see the top tow bolts.
then the radio and a/c panel come straight out,, careful not to scratch the sides of the console.
then you willneed to remove 2 screws either side of the a/c holding it to the cage.
then remove 4 screws holding the rear of teh a/c panel tothe front and there you go..
sorry its not more detialed but i gota shoot out now,
