Climate Control
Tatsunohi
My Toyota Soarer has a half black ac climate control display. It still does its job but it's kind of annoying. I have fond a replacement for it but I was wondering if a control from the Sc 400 would work. I have compared a pic of the sc's and they appear identical with the acception of the buttons have been moved around to accomidate a left hand driver. Does anyone know if this will work in mine. :)
Hi,sounds like the same sort of problem the LS400 suffers from with the display.
Id say if the plugs were the same on the back of the displays for your car,give it a go plug the replacement in and see if it would work :unsure: It can really only blow a fuse.
Good luck
Cheers chips.
