Audio Wiring Diagram
writ10
DO you know if they have an internal or external amp in the car - the wiring is different for each.
You also have to check that the new system can handle the impedence of the existing speakers which are not industry standard (they are 2ohm instead of 4ohm if I remember correctly).
There have been plenty of previous posts on this, so a bit of digging should pull up most of the details.
Ian
