Rx 400 Bluetooth
Which is the best phone that can be used to connect to the RX400H? I have a Motorola but it does not work as well as I would like? My old Nokia 62301 works a bit better. Is Sony Ericsson T610 the phone to go for?
Sony Ericssons work very well. T610 :crying: that's way too old. I recommend one of the following: Sony Ericsson K750i, K600, V600, V800.
My Sony Ericsson K750i is 'paired' with the car, but as soon as I try to send contacts from the phone to the car, the connection drops. Sony, Lexus Customer Services and my dealer have not been any help at all in offering any suggestions as to what the problem could be. :angry:
I've had this happening occasionaly if Bluetooth is kept on for long times on my phone. Try to power the phone off then on and it should work.
The connection is meant to drop so that you can transmit data to the car base unit - once transfer is complete, normal BT connection should be re-established in 5-10 seconds. Problem generally you will find is that after transfering 3-4 line items (say on a 6310i), the phone and car need to be re-set to work normally.
Tony
Right - my local Lexus dealer has given me some information that may help you select what BT phone you may want to pair with the current RX 300 (which in software terms should be the same as the 400h).
Lexus award a star system and 3 star is the most compatible to the RX system whilst 1 star is ok. These are the phone that are available (to my knowledge) in the UK that are in the 3 star category -
Sony Erricsson K700, K750i, S700, T68i, T610, T630, Z600, Z1010
Siemens S55
So there you have it. Hope it works for you.
Tony
