driving to work today,when the radio stopped playing (the tape deck actually cos the radio's cack,import )no power to it,or to the changer in the boot,cant see anything on the rear of the radio headunit and unfortunately the manuals in haaaaaaaa soooooooooo lingo,so dont know which fuse to check or even if i'm looking in the right fuse box ? ( under the dash,below the bonnet pull ?) any help would be appreciated. Ian.
ps,it does help if i say what model it is, 1991 celsior but hoping the fuses will be the same !!
There are few fuses related to radio - one called RADIO (20A) under dash - easy to open a cover, second can be DOME - under hood (left side near to coolant reservoir). On the wiring I see also RADIO 7,5 and it directly supplays power to radio.
PArts location:
  • Topics
  • Our picks
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
      • 0 replies
