Rear Light Install
elexes
If you mean the rear brake light unit, then open the boot, remove the 2 caps next to the light, undo the screws and pull qently.
If you mean the fog lights, remove the boot lid trim by popping out the plugs, then undo the nut, think its 8 or 10mm and push the fog light out gently.
