Hi guys,
sunday night the heater stopped working, well the heating bit has blows cold ok but not heat.I had a quick check around the fuses today and they seem ok.Tonight when i left work i had the wippers on and after a minute or two they slammed up and down then stopped.I tried them again when i got home and they would every now and then go up and down abit.Any ideas ???
Thanks in advance Andy
The wipers have ECU control .
Its high up under the cover under the instrument panel near or on the brake pedal bracket.
It looks like removing the wiper motor and testing it with 12 volts to see if it operates, to eliminate it or blame it..
There are two motors one is called the wiper angle motor
If you can get at the wiper motor plug and disconnect it you can test the motor with 12volts.
Round plug for wiper motor
shaped [square-ish] for angle motor
Hope this of some use!! :duh:
wow where did you get all that info from thanks
