Warning Lights And No Rev Counter
:unsure: Hi Guys. Started the car today and had no rev counter, no mpg clock and the handbrake, low oil and rear brake light warning light stayed on.
The car drives fine, have checked all the bulbs and checked all the fuses. Even disconnected the Battery for an hour to try and clear the fault. There are no codes stored in the ecu either. Its a total mystery.
I have searched the fantastic forum and found 1 other posting like it from 2004 and the guy said it was water leaking in from the windscreen down the back of the dash
Does anybody have anymore information or ideas on how to solve this problem? I want to try and sort the problem myself if poss!!!!!
Hopefully one of you will be able to help me!
