Transmission Fluid
Sagitar
All the previous "automatic" cars that I have driven have used transmission fluid and have had a dipstick to check the level of that fluid.
I can see nothing similar on the IS250 so:
Question 1 - does it use transmission fluid?
Question 2 - if it does, is there a means of checking the level?
To answer my own questions and in case anyone else is interested.
Question 1 - yes, the IS 250 does use transmission fluid and the system is intended to be sealed for life and will not be touched during service unless something goes wrong.
Question 2 - there is an entry point alongside the drain plug under the transmission casing that allows the level to be checked, but it is not intended to be a driver check item.
The source of my information: the mechanic who serviced my IS250 yesterday and who was kind enough to take me into the workshop and "show and tell" in answer to my various questions.
  • 4 months later...
