Problems With My Lsd
maferga
Guys,
I've installed last week an LSD. But when the car is cold, specially in the mornings, I feel an extreme amount of rattle and vibrations on the rear end.
When I installed it I out in Red Line's 75W-90 gear oil, plus 4 Fl. ounces of gear friction modifier.
What could be the problem ? Has anyone installed this ? What Gear oil have you used ?
Mark The problem is that it only vibrates and makes noise at initial use (In the mornings, or after several hours standing), after it heatens the noise and vibrations go out.
What oil do you use ?
Is there anything sold for a total solution ?
What oil do you use if you install a TRD LSD into someone's car ? Do you sell the TRD Gear oil ?
