Windscreen Replacement
GWilso
Hi all
I posted a couple of weeks ago about a lot of exsesive wind noise and creaking front doors after having a new windscreen fitted by Autoglass the other day i took in for an inspection under warrenty at their local office.
They admmitted reluctently that the first screen haddent been bonded/sealed correclty on the drivers side!
What I want to know is if they were to have done any damage to Fuse box or any other parts because of rain damage am I covered in anyway?
GWilso
Have you any damage from the bad fitting ??
If you have, you will have a case :D
If it was only a few weeks ago, i dont thing you will have much damage, if it was me, i would have a look for any water/wet inside, wipe away (if any) run car with heater blowing down to your feet, on max to dry wet/damp(if any)
No obvious water damage at the minute just wanted to check if i was covered if something were to wrong but ill try the drying out thing just in case thanks for the info Gord
