Is This A V8 Soarer Sump?
Dr_G
i would say yes, i have just changed the oil in my V8 soarer and the sump certainly looked like that,
also the veiw under this engine certainly looks like the one in your photos, http://soarer.ace.net.au/oil_and_filter_change.html hope this helps incidently the Ls 400 engine is exactly the same as the soarer though some of the ancillary parts like aircon pumps /pipes etc are different.
  • 6 months later...
The sumps are different !! This is the problem i have. I need an SC400 sump as it sits at the rear, and i have LS400 sump which is pushed to the front :)
Old post - just trying to help
Thanks guys. It turned out it was a Soarer sump, but I need the upper alloy section also as it's also different on the LS400 vs the Soarer. It's for a engine conversion for my Lotus Excel. Have you sorted yours out tuninghouse?
